Oil pressure light issue
659 views 8 replies 3 participants last post by  Bevo
#1 ·
At tick over and when the engine temp gets to approx 72 deg C the oil pressure light comes on, if the throttle is touch the light goes off, does anyone have any ideas? the oil level is correct with 10/30 synthetic oil just been replaced with the oil filter (the issue was there before the ol/filter change).
#4 ·
Right, but the oil pressure changes with RPM. So it's either actually low at idle, or the oil pressure sensor is faulty. I've owned a lot of Hondas and have never had a low pressure light except during the first start after an oil/filter change, which is normal. You'll probably need a qualified motorcycle tech to sort it out.
#8 ·
Owners manual says the following, but doesn't mention about idling on side stand... (ah, i meant in above post.. any difference in oil pressure light between on side stand and upright :) not just checkign oil level)
"Rapid acceleration may momentarily cause the low oil pressure indicator to come on, especially if the oil is at or near the low level."
#9 ·
So before I ride any of my Hondas, I start them on the side stand and let them idle while I put on helmet and gloves. I've never had a low oil pressure warning except during the first start after an oil/filter change and always with the filter pre-filled.
