21 - 22 of 22 Posts
When you say won't start, do you mean won't run or won't turn over?
Does the neutral indicator on the meter work correctly?
Hi, the bike turns over ok but just won’t fire with the stand down, when I lift the bike up and kick the stand up it fires up no problem I changed the diode as believed this was the faulty part but hasn’t made any difference could it be the stand switch ?
any suggestions would be appreciated.
We know the side stand switch works because the engine runs with it up. Can't be that.
The neutral switch can have high resistance that will allow the led to light on the dash to work but not allow it to run. Fun stuff!
Beat on the switch and it might make contact enough to run and verify the issue if you can't take a resistance measurement.
21 - 22 of 22 Posts
