41 - 60 of 73 Posts
Discussion Starter #42
Was looking for a small part that’s on the end of the fuel hose.
In Holland, Germany or England these small plastic things are priced as if they’re made of gold.
When I would place an order in the US the shipping costs are ridiculousy high...€53,-
Why?
Discussion Starter #46
Lager ? i have them at home ... Need one ( or two )? i can post to you in NL
I’ll send you a private message after work, i didn’t know what word to use and I saw you’re from Germany so “auf Lager” must be something like “in storage”. I’ve just looked it up.
Thanks a lot in advance!
Discussion Starter #47
Meanwhile I’ve been re welding the trailer.
Gave it two stands so hooking up is easier.
The thingy that’s connected with the bike.
Behind my bike
This is going to work
Although it looks like a coffin don’t you think?
Sorry for your loss...
Looking good.---:clap
With that Hardy Spicer coupling and an unbalanced load isn't there a chance the trailer could fall onto its side ???
Looks like it could do with two back wheels.---:fingers
I guess the coupling doesn't rotate. Just there for cornering.
Let there be light
All you need now is a rear fender and a couple of flags on poles so that the box drivers can see it and not run it over.---:stop
Discussion Starter #54
I’ve shot this film yesterday while the wind was coming from the side with an force of six Beaufort and to be honest I was a little afraid I would be blown off the road. Empty it weights I guess fifty kilograms so that’s not very heavy. I was surprised to see although the strong wind how stable it was behind the bike and how nimble it is. I’ve drove a bit carefully because of the wet road and the wind and because it was the first time I’ve been doing this. After a while I’ve found my courage back and opened the throttle a bit more and it didn’t feel unsecure once. Took it to 110km/h and still stable. Then applied the brake and it didn’t react strange but noticed the weight. The next time, I hope for a dry day soon, I’ll be carrying more weight, about 50kg extra and I’ll test it again.
TODAYS MYSTERY.-------:confused::confused::confused:
41 - 60 of 73 Posts
