oh dear
the superstand? (basic centre stand?)
You have a choice to avoid all of it too and have a good break relaxing your buttocks & bollocks, have a coffee, smoke your cigar or a joint & chat up the mechanicCan I tell you how much fun it is to change the oil/oil filter, service the air filter, and clean and lube the chain on the NSC when all you have to secure the bike is an abba floor stand? IT'S NOT! 😣
Then after cleaning up and putting everything away, I get to drive to the auto parts store to recycle the used oil and filter.
I do oil/filter/chain with that and.. is fine...
The stand is fine, it's just doing all the work from the floor that sucks.I do oil/filter/chain with that and.. is fine...
I just don't have enough room in the garage.Gotta step up and get the skylift then!
you can probably get a cheap lift table and use the abba stand on that table...
I hear ya.. we ain't getting any youngerThe stand is fine, it's just doing all the work from the floor that sucks.
Something you could try to buildThe stand is fine, it's just doing all the work from the floor that sucks.
This ⬆I just don't have enough room in the garage.
Because lifting the rear helps drain more oil, plus you have to remove the filter from the kickstand side so it helps when the bike is upright.Why put your bike on an Abba stand to change oil and air filter?
Wait what filter have I been removing from the non-kickstand side of the bike?Because lifting the rear helps drain more oil, plus you have to remove the filter from the kickstand side so it helps when the bike is upright.
My last reply was about the air filterWait what filter have I been removing from the non-kickstand side of the bike?
While the oil is draining I'm performing other maintenance.I have an Abba stand, didn't use for the oil and filter change tho.
