1 - 7 of 7 Posts
So, I had a couple of hours spare today - and it wasn't raining for a change - so I went to test ride another CB1000R.
Interesting how one bike can differ to another - this one was not as smooth, it had a lot of free play in the throttle, nothing happened in the first quarter of throttle travel!.
Also the gearbox was a bit notchy, with a definite false neutral between 5th and 6th - really annoying.
Finally, the brakes were nowhere near as sharp as the last one I rode - both were ABS models too!
So, going to see if I can borrow one for the day tomorrow to give it a proper work out!
Anyone else experience these issues?
RBD914
That's interesting, Alan is looking into returning his because of the same problem. Any idea what mileage the demo had clocked up?
The demo bike had 1440 miles on it, the false neutral was more noticeable when you chenged up without the clutch.
What I hear you say - no clutch?!! All the bikes I have owned can go up the gearbox without the clutch - you just take the load off the engine by backing off the throttle slightly and applying gentle pressure to the gear lever and hey presto, in she goes! Takes a bit of practice to get the timing right but once mastered it's much faster when accelerating hard or just being plain lazy - does no damage to the engine, but never, ever do the same thing changing down - now that will knacker the gearbox!
RBD914
Hi RBD. Funny thing is that I thought the play in my throttle seemed more than it should be, but not detrimental to the bikes performance; it's still as smooth as I expected, and it's not as much play as you say, just more than I ever had before. That's something I'll be asking to be looked at while it's in for the first service.
As for the false neutral, can you tell us a bit more about that? As JJON says, Alan has reported something similar on his bike which I believe flared up after something like 60 miles. He reported a (sorry if I'm inaccurate here) clunking/grinding noise at the same time. Can you tell us more about the symptoms that you experienced?
Sure, what I found was like 2 notches between 5th and 6th, unless you were really deliberate with the gear change it slipped into a false neutral really easily. I coud definitely feel a distinct resistance in the gear change. It was more pronounced with a clutchless gear change. However I found the entire gearbox very notchy i.e. not very smooth or precise on this particular bike. Whereas the first bike I test rode was smooth as silk in the gearbox department - never missed a gear, no false neutrals and it changed up without using clutch, no problem at all.
Maybe it's an early production run glitch - I would get it back to the dealers, test ride another for comparison, and not accept it back until fixed. Hey, it's only gonna get worse!
Good Luck - let us know the result.
RBD914
Yes, travel distance between 5/6 ratios seem a bit further, just boot up firmly. Am currently more concerned about suspension settings as brisk motorway progress has the forks extending and the rear squatting like a bear in the woods. (even when kinda lying down on the tank).
BTW, checked speedo against Sat Nav: 32 on bike =30, 43=40, 66= 60 and .....erm 133 = 128.
1 - 7 of 7 Posts
