I agree, except you want an LiFePO4 battery. I had a Shorai on my last bike (CB600F) that lasted more than 10 years. It could also sit all winter without a tender and crank right up in the Spring.Just buy a little LI IO cells 16/18 AH instead of 2 batteries
A bigger battery might be an answer.I agree, except you want an LiFePO4 battery.
A ten year's bike I had.I had a Shorai on my last bike (CB600F) that lasted more than 10 years. It could also sit all winter without a tender and crank right up in the Spring.
i meant cells not a batterieI agree, except you want an LiFePO4 battery. I had a Shorai on my last bike (CB600F) that lasted more than 10 years. It could also sit all winter without a tender and crank right up in the Spring.
Not very clear. A bunch of 18650s and a BMS? The Shorai is essentially that except packaged for consumer use, with better battery chemistry for automotive use.i meant cells not a batterie
yes could be see like that , the space it is the main issue , and a "shorai" will be too big for. ( nope not 18650)Not very clear. A bunch of 18650s and a BMS? The Shorai is essentially that except packaged for consumer use, with better battery chemistry for automotive use.
Interesting, I haven't seen a kit that uses Lithium Iron cells like that. Still this is not much different than the Shorai in size, cost and capacity.LiNANO® 8 Ah 12V HP25C LiFePO-Starterbatterie - BAUSATZ, Lipopower, L
LiNANO 8 Ah 12V LiFepo-Starter-BatterieSL-FHWS als Bausatz, bestehend aus den neuen, noch leistungsstärkeren 25C HP-Zellen Der ideale Ersatz für 12V Bleiakkus in Motorrädern, Flugzeugen, Booten und AutosLieferumfang des Basis-Bausatzes:4 Stück 8Ah Headway-Zellen 38120HP4 Stück Zellenhalter3...shop.lipopower.de
I had a Shorai in my 2014. Worked fine but I did notice the engine would turn over slower in cooler weather.Shorai LFX09L2-BS12
They definitely do that. Almost the opposite of Lead Acid batteries though. Rather than getting weaker if you crank them while cold, they actually warm up and perform better. Shorai recommends running the headlight for a few minutes before trying to start it in the cold.I had a Shorai in my 2014. Worked fine but I did notice the engine would turn over slower in cooler weather.
Yeah.Shorai recommends running the headlight for a few minutes before trying to start it in the cold.
the sc77 got a LiFePO4 , pretty special and expensive unit.Yeah.
The OEM Li-ion in my SC77 starts the same regardless of ambient temps in Houston.
