1 - 10 of 10 Posts
I am searching for a rear stand and am coming up blank. I live in the US and I looked at the one from ermax, however the product is 108 Euros, but the shipping is another 136. That's a bit pricey :) I am going to get some sliders so I could go for a lift that just has a hook rather than trying to find one for the 18mm hole in the wheel. Are there any recommendations out there?
Thanks, Guy
Thanks, Guy
Get the ABBA Superbike lift, I live in Canada and just received mine, it works great
Abba Superbike Lift. At least the basic model with the front tire lift. I use it on all of my bikes as you can buy adapters if the included ones won’t fit your new ride. They are a little pricey, but extremely high-quality and the last lift you will need. Also their customer service on any needs you have is outstanding. Probably because they’re British!
Sent from my iPhone using Tapatalk
Same here - R&G Spools and then use any regular rear stand. Mines a Powerstands one as they pretty cheap, but nicely made.
I have the R&G rear spools with a rear stand that looks like this: https://www.amazon.com/SPECSTAR-Motorcycle-Universal-Swingarm-Kawasaki/dp/B0894JRVXF/
It works okay, but it isn't as stable or secure as I would like it to be. I only use the setup because I already had the stand from my old bike.
Spools or Spindle Sliders? Are you able to remove the rear wheel?
1 - 10 of 10 Posts
