Hi All,
Hope someone can help or assist or point me to a solution. Over the last couple of weeks I have noticed that my chain is very loose and thought it is just stretched. But I have now noticed that it is the wheel/hub that keeps moving forward. So I have checked my flange/Pinch bolt and the torque is at 74nM.
So I loosen the bolt again, adjusted the chain and then tightened again, this time just passed 74nM. It is now almost two weeks but noticed this morning it has started again. If I look at the chain tensioner indicator, I can see it moved and is not on the same mark anymore.
Previously I also tried to remove the bolt but it seems as if it only loosen a turn or 2 and then get stuck, but looking at the diagrams it seems the bolt is suppose to completely come out? Should I just keep turning until it is out? Just scared I will damage the swing arm.
Not sure what to do or how to get this resolved? I also can't tighten it too much as it might strip?
Thanks.
Thanks.
