Power commander 5 ignition module one year old £200 was £300 new only removing as fitting stand-alone ecu email me on [email protected]
Wow..... seems an odd thing to buy new then. CheersVirtually nothing and even needs more money spent to get the little it could give to our low revving CB 1,000s.
Not a fan of the PC5. But having the ECU reflashed by Don at guhlmotors.com is the way to go. Cost is $375 total including overnight shipping back to you!
Another bright response from someone who has no clue about performance upgrades. Colvert I thought you will stick with granny riding stuff and not comment on new age performance upgrades you will never even consider?Virtually nothing and even needs more money spent to get the little it could give to our low revving CB 1,000s.
List of features below:
Allows +/-20 degrees of timing adjustment
Raise your Rev Limit (only available on select models)
Adjust timing based on temperature or boost inputs
Built In Launch Limiter
Individual Cylinder Timing
Gear Position Timing
Boost/Nitrous Retard Timing
Pit Lane Limiter
Also like OP, my bike had about 10HP power increase just from ignition timing advance.
were you actually able to increase the rev limit ?( beyond i think 11k - 11.2k)I was using it to up the revlimit 500 rpm plus launch limiter plus almost 10hp with added ignition advance
