Optional Combined-ABS Version
The new CB1000R is also available in an advanced Combined-ABS configuration that features the powerfully reassuring braking control of Honda’s long-proven Combined Brake System coupled with the smooth, confidence-inspiring operation of its popular Antilock Brake System. Visually, the only major difference between the CB1000R’s standard and Combined-ABS versions are its front callipers and lower fork castings. Replacing the standard version’s high-performance radial-mount 4-piston callipers are a set of responsive three-piston callipers gripping the same 310mm floating rotors. Each wheel also mounts a small pulsar ring, which is constantly monitored by the Antilock Brake System.
The ABS portion of the CB1000R’s highly effective Combined Antilock Brake system operates in precisely the same way as Honda’s other ABS-equipped models. When braking over uneven or slippery road surfaces, this high-accuracy system instantly reacts to the most minute variations in the relative speed of the two wheels, predicting and counteracting tyre slip before it occurs. With precise control, this system maintains just enough brake pressure for smooth and steadily controlled deceleration that greatly enhances confidence in the CB1000R’s ability to stop quickly and surely.
Its proven Combined Brake System links the rear brake pedal to both the compact dual-piston rear brake calliper and the centre piston of its right-side three-piston front brake calliper to provide a measured balance of front brake control whenever the rear brake is firmly used. An inline delay valve ensures that light operation of the rear brake, such as when trailing through a corner, has little or no effect on front brake operation.
Stronger pressure applied to the rear brake pedal results in just enough front brake engagement to provide a more effective balance of front and rear braking forces for smoothly controlled operation. The remaining five pistons of the two three-piston front brake callipers are controlled in a conventional manner by the hand brake lever and provide reassuringly strong braking control to match the CB1000R’s aggressive sportbike riding capability.
Aggressive and confident sportbike riding also requires strongly assured braking performance, and the CB1000R’s advanced Combined-ABS version provides an exceptional level of smoothly responsive braking control to give all riders more confident stopping power in situations where optimal braking capability is crucial.
