2065 ? You are well ahead of our time.> so I bought a 2065 CB1000RA
I doubt there's a can for a 2065I bought a 2065 CB1000RA
Pmsl!! It’s a HovaHonda… late 15 plateWelcome to the Forum.
2065 ? You are well ahead of our time.![]()
I was just pulling your sock.Pmsl!! It’s a HovaHonda… late 15 plate
This is my 2014 the day I traded it in. It has an Akrapovič open slip-on (CAT delete) with required Power Commander featuring a downloaded map designed by Akrapovič. I removed the DB killer but there's also a map designed for use with the DB killer. They also offer a slip-on with a mid pipe that attaches to the CAT (street legal) that doesn't require the Power Commander.Thinking of changing the end can, something not too loud but makes the bike sound like a 1000cc and not a 500. Any thoughts??
The heat when the fans kick on from a sportbike is really bad since the fairings focus it on your legs. I don't find the Streetfighter or the NSC bad at all. Sometimes these engines will "lope" at idle from a hot start, but I've not noticed anything unusual and today I rode in 99F / 37C temps.However I have also noticed recently the idle is a bit sporadic, not by a lot but noticeable.
is this a common thing with these engines?
Treat it to a tank full of decent Shell or Esso E5 petrol not supermarket stuff. If it’s not been used a lot maybe consider a splash of Redex or similar to clean the tubes out a bit. Hope you enjoy the bike and yes riding nowadays compared to 20 years ago is a whole new thing. Much more congestion, many more idiots, many more speed cameras, potholes and petrol is like liquid gold (to buy). Apart from that it’s great 👍😬👍Hi fellow riders,
I have found riding it in the current climate a bit of a challenge. It easily peaks temp for the fans to kick in but omg the heat from the engine when at lights etc is really uncomfortable when it’s already high temperatures. However I have also noticed recently the idle is a bit sporadic, not by a lot but noticeable.
I only use regular unleaded in my 2014 and 2019 because that's what the manual calls for. Only super unleaded in my SC77 SP because that's what the manual calls for. Always Shell in all my vehicles.I’ve only put in normal unleaded
2015 US manual. 87 PON (US regular) = 91.1 RON (UK)My manual states the fuel needs to be unleaded 91 octane or higher
That's not a current photo, but yeah it was $2.399. In Houston gasoline starts at $4.00 a gallon.Can’t see the decimal points on the gauge, is that really $2.399 a gallon?
Yes, Dallas is in Texas. Houston is about 3.5 hours south.Used to love Dallas on tv back in the day, that was Texas wasn’t it?
