1 - 3 of 3 Posts
I need to know the length of the hose from the reservoir to the shock body. I'm having a custom shock built and having this information will allow me to make sure that the hose is that the correct length.
Thank you, Bart
from the end of the fitting to the end of the other fitting 330 mm the hose without fittings should be about 300 mm (can't get exact hose only length cause i can\t see how far into the fitting it goes)
hope that helps mine is still in the box waiting for me to get fork spring kit before installation
1 - 3 of 3 Posts
