1 - 10 of 10 Posts
Hey fellas,
Just been reading through and getting some ideas. Purchase a few days ago a used 2018 CB1000R with 2800kms on it.
From what a I can see it has tail tidy, SD-R levers and full SC-Project S1 exhaust.
How’s everyone finding the sound from a slip-on? Does it satisfy the desire for more sound ? I’m finding the sound a bit much and would expect a ticket in the near future if I crossed paths with a cop in the wrong day…thinking I may switched back to stock and use slip-on only, any thoughts ?
Other than that, finding the bike fantastic. Have ridden plenty of bikes up to an R1 in the past but only owned personally a CBR500, CMX500 and then most recently CB650F. Finding the NSC has plenty of power but very tame and manageable low down.
Wheel Tire Fuel tank Plant Vehicle
Welcome
Does the bike a have a tuning device for the full exhaust like Rapid Bike or Power Commander?
No, and the more I’m reading the more that concerns me a bit. I bought it from a dealer. No further information on the history I can find I’ll have to look through the documentation when I get a chance. Hoping it was flash/dyno tuned
you should be able to get a db killer
I'm liking the coordinated bluing of the exhausts...
I thought perfect solution to the problem so I went and had a double check… db killer is in ha- by the looks of things…
Tire Wheel Automotive tire Motor vehicle Tread
I wasn’t initially a fan of the bluing but it has grown on me
Wheel Tire Fuel tank Vehicle Automotive tail & brake light
Thanks for the advice either way!
I went and picked up the stockexhaust from the dealer today. I’ll have to research a bit more but seems like I’ll be needing some clasps and the link pipe to go back to stock with slip-on.
Super Duper Moderator
@doser @Bevo Besides the DB killer in the SC- Project slip on, is there anything else inside that can be taken out ? Reason for ask, some one mentioned to me there is something else inside that can be taken out , which changes the sound and also if you were to take "this" thing out & put a full exhaust , you do not need to flash it . IDK if it is true or he was joking about it . :confused:
The dB killer on my SC-Project slip-on can't be removed. Some mufflers have baffles that can be replaced. No idea on my SC. As long as you keep the CAT you probably won't need a flash or a tune.
I have edited @n02 pic to show what I have taken out. It was a tough job to get it out . I took off the C-clamp and then took a big broad pipe and hammered it out so badly, that it is now useless to use it again. Basically the flat side got almost punctured with all the hammering.
I was wondering if there was anything else that can taken off.
Tire Wheel Automotive tire Automotive lighting Motor vehicle
· Super Moderator
The dB killer (which is what you removed) is really the only thing that's supposed to be out of the muffler while the bike is operating.
1 - 10 of 10 Posts
