1 - 8 of 8 Posts
Gents,
My CB1R sounds like it has an engine rattle when at low revs (1-2k) like noisy tappets on a car. the noise goes when the engine is revved, any ideas? (the bikes only done 6k and has a full service history).
Have you check all the exhaust shields to ensure nothing is loose, actually check any connection to the engine as the low revs coul dbe causing a vibration from hitting the righ frequency...just a lame guess...
Got any oil in it. :)
Cheers gents, just had a service Jon.f so full of oil. ill check all bolts etc when i get in but it sounds more engine rattle than something external rattling.
My bike does the same thing only at low rpm. it is definately a valve rattle. In my opinion its octane related. the highest octane available around here outta the pump is 93. i tried some race gas(116 octane) and the noise went away. i can live with the low rpm valve rattle on pump gas, im not gonna spend $16.75/gal to get rid of it.
...mine has a bit of a slight tappety sound at almost dead on 3k revs - ok below , fine above - just an engine foible ! Power and drive are fine , no tickover noises, no backlash noises when revving - engines are noisy as they have pistons and rotating valves etc and I think some will just be naturally more noisy than others - if in doubt check the valve clearances etc - the Hornet did the same thing but still going strong !
1 - 8 of 8 Posts
