A guy at work showed me a demo today that has REALLY impressed me. You can download it from here.
Basically, it's a 3D rendered scene where EVERYTHING is mathematically generated. The shapes, the textures and the sounds. All that and it's only a 177KB file. Bear in mind that a megabyte is 1024KB and a gigabyte is 1024KB! A video (low res) of the demo is 164.3MB in size and the hi-res video is 197.6MB!
I've just watched it at 1600x1200 on my PC. Put that in perspective like this: a 1600x1200 plain white JPEG with a 60% quality level saved from Photoshop is 22.27KB in size. So you can only get just under 8 of these images to the size of the demo itself.
The actually content of the demo is not going to set the world alight, but if you can appreciate the awesome technical achievement of this demo then you should really take a look.
The required/recommended specs are as follows:
Minimum Specs:
P4 2GHz or Athlon XP 2000+
512MB RAM
Pixel Shader 2 capable graphics card with 128MB RAM
DirectX 9.0c
Recommended Specs:
Core2Duo or Athlon64 X2 >2.4GHz
1024MB RAM
GeForce 7600/Radeon X1600 or better with 256MB RAM
If you're impressed then maybe you might want to look at the earlier 'Kkrieger' demo which is the same kinda thing only it's a game demo that's completely mathematically generated and weighs in at only 95KB
Both are technically VERY impressive if you understand what they've done
Minimum Specs:
512MB RAM
DirectX 9.0c
Recommended Specs:
1024MB RAM
