1 - 3 of 3 Posts
I have just inspected the front brake pads on my 2019 CB1000R, the pads look fine in the Tokico calipers, however when it comes to fit new ones or just clean out crud etc......HOW do you take the pads out? No sign of any pins that hold pads in place, just lots of sprung steel clips.
I have not looked at the rear caliper/pads yet......any tips to remove the pads and clean up pistons etc?
Discussion Starter #2
Looking now at the rear caliper and its a NISSIN one with a pin through the pads so shouldn't be a problem. Might be easyer to remove the rear wheel first. This is made much better with an ABBA stand to lift the rear end up.
Problem solved by myself.
Remove the two caliper bolts, push the pistons back by twisting the caliper on the disc, move one brake pad way from the piston into a central location and pop out the pad, remove the other pad exactly the same way.
Clean all items and re-assemble in reverse order. Don't forget to move brake lever to push pads upto disc before riding bike.
1 - 3 of 3 Posts
