1 - 2 of 2 Posts
Just spotted that myself, thought they were taking their sweet time enabling that site!
eBrochure
Gallery
Specification
360degree View
That's all there is
Just to clarify the specification for all:
[horizline][/horizline]
Spec Details:
  • Price
    On the road excluding road taxes
  • CB1000R £6,950[/*:m]
  • CB1000RA £7,450
    Engine[/*:m]
  • Type: Liquid cooled 4-stroke 16-valve DOHC inline-4[/*:m]
  • Displacement: 998cm3[/*:m]
  • Bore x Stroke: 75 x 56.5mm[/*:m]
  • Compression Ratio: 11.2:1[/*:m]
  • Max. Power Output: 92kW / 10,000min-1 (95/1/EC)[/*:m]
  • Max. Torque: 99Nm / 7,750min-1 (95/1/EC)
    Fuel System[/*:m]
  • Carburation: PGM-FI electronic fuel injection[/*:m]
  • Throttle Bore: 36mm[/*:m]
  • Fuel Tank Capacity: 17 litres (inluding 4-litre LCD-indicated reserve)
    Electrical System[/*:m]
  • Ignition System: Computer-controlled digital transistroised with electronic advance
    Drivetrain[/*:m]
  • Clutch: Wet, multiplate with coil springs[/*:m]
  • Clutch Operation: Hydraulic[/*:m]
  • Transmission: 6-speed[/*:m]
  • Final Drive: #530 O-ring sealed chain
    Frame[/*:m]
  • Type: Mono-backbone; cast aluminium
    Chassis[/*:m]
  • Dimensions: 2,105 x 785 x 1,095mm[/*:m]
  • Wheelbase: 1,445mm[/*:m]
  • Seat Height: 825mm[/*:m]
  • Ground Clearance: 130mm[/*:m]
  • Kerb Weight: 217kg (F:106kg; R:111kg), *222kg (F:108kg; R:114kg)
    Suspension[/*:m]
  • Type:
    • Front: 43mm inverted HMAS cartridge-type telescopic fork with stepless preload, compression and rebound adjustment, 120mm cushion stroke[/*:m]
    • Rear: Monoshock with gas-charged HMAS damper featuring 10-step preload and stepless rebound damping adjustment, 128mm axle travel[/*:m]
    Wheels[/*:m]
  • Type:
    • Front: Closed-section 4-spoke cast aluminium[/*:m]
    • Rear: Closed-section 4-spoke cast aluminium[/*:m]
    [/*:m]
  • Rim Size:
    • Front: 17M/C x MT3.50[/*:m]
    • Rear: 17M/C x MT5.50[/*:m]
    [/*:m]
  • Tyre Size:
    • Front: 120/70 ZR17M/C (58W)[/*:m]
    • Rear: 180/55 ZR17M/C (73W)[/*:m]
    Brakes[/*:m]
  • Type:[/*:m]
  • Front: 310 x 4.5mm dual hydraulic disc with 4-piston (*Combined 3-piston) callipers, floating rotors (*ABS) and sintered metal pads[/*:m]
  • Rear: 256 x 5mm hydraulic disc with dual-piston calliper (*ABS) and sintered metal pads
    * Combined-ABS version[/*:m][/list:u]
1 - 2 of 2 Posts
