1 - 18 of 18 Posts
Its was strange i was riding and hit a little bit the headers the bike turn off and when i try turn in on dont cranks and the gauge blinks power, engine brake, traccion and temperature
This happened to me took ecu connector out
Took all fuses out corrosion good clean with electric cleaner
Discussion Starter · #8 ·
I check and i asee i hit the left oxygen sensor and that make me a problem but i dont know what kind of problem, the motorcycle dont crank and on the gauge the power, tempeture all blinks
Any electric connectors you can see take them apart good clean
Think it is electrical bad earth check battery terminals & side stand as well
Esta extraño porque la moto iba súper bien pero al golpear lo headers como que subió levemente y dañó el sensor de oxígeno y los cables estaban pelados no sé si harían algún corto circuito pero todos los fusibles estaban bien
1 - 18 of 18 Posts
