1 - 18 of 18 Posts
One day i come to garage ,i try to start and i notice the fuel light blinking is low.i fill up with fresh fuel ,about 15 -16liters ans try to start and not starting ,after i take out one spark plug i noticed was vet and i noticed is looking not nice maybe is spark plugs problem??
Discussion Starter · #14 ·
water in the fuel from the garage?
can you drain someof the fuel and look for water?
or.. filled up with diesel? :)
For sure it waa not diesel.recently i check fuel tank it is fresh new gasoline
Discussion Starter · #17 ·
Gas station, garage, servo etc.. same same. ;)
If bike could start before filling up, and then not start after filling up.... Maybe something to do with what was filled up with :)
I found that in fuel tank alot trash,i clean fuel pump with air preasure ,and then i make test , about 600ml fuel was black with trash ,after this i put fresh fuel again and motorcycle start.
1 - 18 of 18 Posts
