1 - 9 of 9 Posts
The manual for my loaner is under the seat...
How do I get the seat off? How do I get the pillion seat off?
:emb
There is a lock to the left of where the number plate hanger connects to the tail as you look from behind. That releases the pillion seat. The riders seat is bolted down from under there, but under it is only things like the shock, ECU and fuses
Thanks, I'll go try straight away!
... Shame about the riders seat - I wanted to look at the flasher relay. Saw a picture of the Z1000 one today; it said 21W + 10W + LED meaning it could be used for both 10W and 21W and LEDS!!!
You can still get to it, it's only one allen bolt, and it's a size that you get a key for in the toolkit too :thumbup
Cool, I'll do that tomorrow!
The hole the lock is in was hard to locate! I was starting to wonder if I was mad till I found it!
Ha ha. I must admit that I'd studied the photos so hard that I knew where it was before the bike was any where near launch, but even so it's not the easiest of keyholes to use anyway :banghead
Thanks Antnee! I've been huntin' for my hole since 2012!
:p:rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes:
I don't think Antnee will see your post as he has been hunting for the FORUM for years. Still not found it.---🔦
Hey, I figure if everyone else is doing it, I might as well join in!
Reactions: Ghostrider.1127
1 - 9 of 9 Posts
