1 - 20 of 110 Posts
picked up yesterday some other wheels for my cb 1000r
my wheels are new ; well is winter cannot drive let´s make some test :D
Alloy wheel Rim Spoke Wheel Tire
Alloy wheel Spoke Rim Wheel Auto part
modification i did at my bike ( 2015 reg. ) corrently:
arrow full header 4-2-1 and tri oval double exit Can
pc5 -ignition unit- quickshifter
k-n filter (modified airbox)
hrc camshaft/sprockets (endurance) for cbr1000rr 2004
ported/skimmed head
Cbr1000rr Stick coils
wilbers rear shock (+6 mm longer)
14 vfr 1200f front forks
nissin six pot radial calipers
320 mm front rotors (12.5 offset)
11 vfr 800 rear wheel
12 cb1300 abs front wheel
silicon cooling hoses in black
nissin brake and radial master (kawasaki 1400 oem unit) with rizoma res.
trw rearset with rizoma res.
changed few screws with black alu from probolt
rizoma mirrors (fitted with two oem bracket from clutch side)
garmin zumo navi (i have one in all my bikes)
black painted rear footstep
bodystyle bellypan and rear hugger
scottoiler E version
healtech speedohealer and Gipro
shifholder from gilles tooling
tailtidy and 4 signals
sure i forgot something
so next step , let see how will look with those wheels:thumbup
pics ? bikes still inside in the kitchen/snow outside :cry
will put to fine tune on dyno in feb-mar. as bike was 0 km when i did all , so i started with pc map and refine with autotune (also have feeling is far from be perfect)
With the cam timing and head skim I'd suspect that with both ignition and fuelling needing a remap that auto tune will struggle to compensate - have you converted from ABS to non-ABS with your front brake system or have you just swapped ABS Nissins for ABS Nissins ?
just the two master cylinder (most also the brake unit for aspect/color) , but i already have an idea how to keep abs , fitting radial calipers , without blank the brake line for save the cbs system
Auto part Technology Automotive lighting Vehicle
Auto part Technology Vehicle
actually i bought all the spares after coz mine is a 2014 model registered in 2015
Discussion Starter · #8 ·
wheels are here with some are bling
Auto part Exhaust manifold Pipe
Some questions:
What's the front wheel off of? I've tried finding fronts to match my VFR rear and nothing fit. Yours looks like an SP-2 front? Guess you'd need a different axle? Interested in seeing how you've fit it and what's required! Here's my 8 spoke rear with ugly 4 spoke front:
Land vehicle Vehicle Motorcycle Car Rim
Also, the CBR1000RR camshaft hasn't been a good swap in the past, have you found something out? Those are cams designed for a downdraft, dual injection set up reaching almost 14,000 RPM's. I can't imagine they'd be much of an upgrade at all for this bike considering its tuning and design. The CB's design is limited by packaging and I haven't seen a successful RR parts swap done before.
I'm by no means saying it won't or can't, just from previous experience reading up on this it wasn't worth it. If you have some secrets I'd like to know :)
Discussion Starter · #10 ·
i used hrc endurance cams (cores with regrind) sure U will lost some low range ponies
But may u mistake : cbr1000rr at 14000 ?
hrc ecu is limited to 13500 (with cams, spring valves) and is quite the higher point b4 U split all on an middly tuned engine from this years
those engines came with 12400 limiter (fuel cut) on 04-05 and for 06-07 bit higher
some wsbk full hrc engine got a 500-750 rpm bonus (but was not part of commercial hrc kit)
i decided to get 1000 rpm extension limiter from the pc5 btw
used hrc core cause more lift
U re lucky was searching like crazy a rear wheel like yours!!! than i bought this two....
but we can exchange them :D
or u can match your rear one with front one out of a vtr sp1
(need new spacers and new bearing, sealing , middle spacer)
folow rules for cbr1000rr 04-07 conversion as front wheel are the same :respekt
Rvt100r RC51 Wheel Swap info - Page 11 - Honda CBR1000 Forum : 1000RR.net
HONDA VTR SP1 RC51 RVT1000R 2000 2001 00 01 FRONT WHEEL RIM FELGE VORDERRAD | eBay
Discussion Starter · #11 · (Edited)
forgot my front wheel is out of a cb1300 abs , same size for bearings and so on , no trouble fitting abs phonic wheel as threads are already cut , may need new spacers
quite a 1-1 swap
just realized u are from US , may not so easy find a cb1300 wheel ... shit
I believed the issue with CBR cams in the CB is also valve stroke length. The CBR has much higher cam lift and the CB springs are not designed to accept this length. Again, this is only what I've heard and have never actually put parts on a bike to verify myself.
That post on the CBR forum says the guy eventually abandoned the idea after realizing the rotors are off by a few MM and were rubbing. i hope you read on and realize it's much more than the one page you sent me:
"Conclusion, Not worth it...
I have a buddy who can machine and what not...but if you look inside the wheel, there isnt much room for machining.
and the stock RC rotors are ugly and twice the weight of the 1000 rotors.
I picked the RC wheels up with the rotors attached and it was heavy as hell.
Final Note: Ditch the idea, sell the wheels for good money and save up for 2012 wheels when they pop up on ebay, which will still be cheaper than 1500 aftermarkets."
Ok. I have gone way too far to dismiss this mod. Hopefully, with everyone's help, we will be able to find a resolution to this.
Based on YZFRZONE's measurements of:
RC51 wheel with RC51 rotors (Rotor-to-Rotor Distance): 5-19/32"
08 1000RR Wheel with 1000RR rotors (Rotor-to-Rotor Distance): 5-14/32"
RC51 and 1000RR rotors having the same height of 12.5mm
The difference is 5/32" = 3.96875mm = 2 x 1.984375mm
Therefore, I am going to have my RC51 wheels machined by 1.984375mm on each side. Here is a diagram that I have made.
Discussion Starter · #13 · (Edited)
valve springs on cb1000r are the same on cbr1000rr 04-05 ,(even same spare part number...)
i linked to U to the wrong thread , sorry ( i was refer to cbr1000rr 04-07 not the 08>)
Do RC51 wheels fit 1000rr?? - Honda CBR1000 Forum : 1000RR.net
sp1 wheels are heavy compared to cbr 1k wheels (sp2 bit lighter), not compared to cb wheels ....
(but it s even not my problem cause i got a cb1300)
rotor height? you mean offset
we can talk about also cbr1k wheels swap , but may that s not the right thread
u can see here my orange wheels b4 the pvm :p
08 Front End Swap? - Honda CBR1000 Forum : 1000RR.net
sometimes on forums is difficult to me understand other members
may cause bikes are my job/life (working even for honda now ), so what is for me natural may for others is not..... :thumbup
rotor height? you mean offset ....
may cause bikes are my job/life (i m even working for honda now) so what is for me natural may for others is not..... :thumbup
I too work for Honda (American Honda Motor Co.)
Hello buddy!
I see the valve springs are the same, so maybe you're on to something. I figured with only 1 stage injectors and side-draft intake that the design would still be very different. I am interested to hear what your bike feels like after the shaft then!
Here's the thread where someone else put a CBR (2007 though) camshaft into a CB: http://www.hondacb1000r.com/forums/...rched-pulled-trigger-different-camshafts.html
I own a 2006 RC51 and hve never tried to measure anything. I also own a 2007 CBR600RR and I know those rotors are exactly the same!
I'll do some research of my own, I would love SP2 wheels on my RC. My parts list them as 4lbs lighter!!
Discussion Starter · #15 ·
Forgot to say , also running schnitz racing injectors
06-07 cbr1k got double springs for avoid issue an high rev
that s tell me the single on older version were maybe already to the limit ... that s why i decided to stay under 12000 with oem pistons (not worked deck) on the cb
i hope to reach 150 hp
bike with same setup/head work of mine did so:
Text Line Slope Plot Design
Wow how cool.
I have 35,000 miles on my CB and wouldn't mind playing around with this one bit. You will likely need to change ignition advance as well i'm sure?
Discussion Starter · #17 ·
I already fitted the dynojet module but did not went that far , bit early till 6500 rpm than quite oem curve
Discussion Starter · #18 ·
Actually there is a cb1300 wheel for 250$ on eBay.com (New York area)😈
Discussion Starter · #20 ·
U mean web epc? in Honda maris?
Text Line Font Diagram Parallel
Is quite a direct swap (may need new spacers for front axle)
as, if they "design" is like the sp2 wheel
the size of the bearing / seals is the same (bearing 20X45X12 91052-MBW-E11 , seal 28X47.2X7 91252-MC4-013)
spacing between discs faces is also equal ( 133.6 mm +/- 0.2)
(and in my case i have the place to fit the phonic wheel for abs , than sp1-and sp2 had not )
1 - 20 of 110 Posts
