1 - 5 of 5 Posts
Hi all
First post. I was recently riding out on my 2011 CB, and whilst I changed gear up. The gear lever went all the way up, 90 degrees from its usual angle. I pushed it back down with my foot and there doesn't appear to be any ongoing issues. Will this have cause any damage? And has this happened to anyone else?
If that has happened you have something wrong. Just pushing up the gear lever WON'T fix it.
Make sure the fixings are done up tight. In the gear lever itself.
The top link you can see the splines on the input shaft. Check the pinch bolt is tight.
cbbeaut-------------------I see you looked in today. Did you get that gear lever fixed ????
Hi
I had a friend of mine look at it and couldn't see any issues with, I've since changed the height of the gear and lowered so my foot sits better underneath it, I haven't had any further issues.
1 - 5 of 5 Posts
