1 - 3 of 3 Posts
I always mount & balance tires on everything I own. However, I have never had a single sided single arm bike with no bearings in the wheel. I use a static balancer that essentially pinches a rim onto a steel bar w/ bearings. My issues was that no one lists what size adapter to use for the drive/hub side of the rear wheel. The non drive side of the front wheel is very small and my universal balancing cones fit fine. The driver side is very large and actually tapers down, it was going to need a special cone.
I did some looking around & found Motorcycle Wheel Balancer Marc sells motorcycle tire balancers and cones. I got with Marc and took some measurements. We concluded that the VFR cone was almost an exact match. Marc has a VFR cone for sale and shipped it out. I can now confirm that the VFR balancing cone he sells works great.
Just thought I'd let everyone know. Not even the Honda dealerships around me are equipped to balance the CB1000R wheels, it's quite sad. There is essentially no dealer support here in the US for these bikes. You UK guys hit gold especially with dealers like Doble.
Here is the cone:
​All the dealers over here use dynamic balancers. Don't you find the need for that as well as static balancing ???
Your are correct, dynamic is superior. However, I haven't ever the need for dynamic on a motorcycle. Generally motorcycle wheels are narrow enough to get by with static. I always use dynamic on my automotive wheels do to width. I have always had great success with static balancing but I have heard of people still having vibration issues. In this instance it would be advisable to dynamic balance motorcycle wheels. You can also split up the weight on a static balancer to simulate a dynamic balance, it takes some skill/practice but can be done.
That being said I would love to have my motorcycle wheels dynamic balanced. There just aren't any shops or dealerships around me that use a computerized dynamic wheel balancer for motorcycle wheels, most use the same static balance I use (even BMW.) Secondly, the rear wheel would be easy enough to dynamic balance on an automotive dynamic balancer but the front would be much harder due to the bearings. Third, I'm cheap and static balancing is very easy.
I'm sure if you are in a much larger city in the USA you could readily come across shops that dynamic balance motorcycle tires, just not around my location.
1 - 3 of 3 Posts
