1 - 2 of 2 Posts
A drop comming every second from behind water pump when engine is running. I first thought it is seal Leak. But after replacing i found it is coming from back side of the pump. There is a hole. Pls check the attachment. Can any one explain why its leaking?
Sorry to be bearer of bad tidings, but these pumps have a bushing back there. The hole is probably a weephole. From my experience, the pumps are not rebuildable (at least easily) - Honda don't sell any internal bush rebuild kits from what I've seen. Best bet is to try and source a used pump on eBay.
1 - 2 of 2 Posts
