It shouldn't. Did you measure the chain slack?I had chain tighted after 120 miles. And now just before 600 miles Frist service due it needs doing again?
How loose? Is the chain stretched evenly or does it have loose, tight spots? FYI, that's the same sized chain that's on the SC77.The dealers done it then I took a pic where it should be and now it's loose again I do trash it.
On Cb it sits pretty loose but when honda tighted it if you press it up midway it sits away from the guard at moment all of it is touching. I'll post pick after honda tighted itHow loose? Is the chain stretched evenly or does it have loose, tight spots? FYI, that's the same sized chain that's on the SC77.
When I first noticed it after 120 miles it was really loose to the point you could slightly hear it but honda said it wasn't very loose but needing doing.How loose? Is the chain stretched evenly or does it have loose, tight spots? FYI, that's the same sized chain that's on the SC77.
Check the label on the swingarm or the spec in the manual for proper slack. I've had a 2014 CB and now a 2019 CB, so I'm aware of chain slack.When I first noticed it after 120 miles it was really loose to the point you could slightly hear it but honda said it wasn't very loose but needing doing.
All chains stretch over time but at different rates depending on how they're ridden and how they're maintained.Yep, mine keeps on stretching too, I'm at about 7k miles and I've had mine done twice, probably have them do it as part of the service thats coming up soon.
6mmTools needed to do the adjustment I have the stand. Just need to know the heads and contraption to reach in there.
