I need some wiring help & expertise.
This is what I did.
Any help with a picture explanation will do
This is what I did.
I picked up a set of Denali D7 Auxiliary Lights from Steve @ A Bike Thing
I also picked up a Thunderbox - Model TB-U02 - Thunder Box (TB) - HealTech Electronics Ltd.
I wired up the Thunderbox with the wires +ve and -ve going to the Battery.
I wired the auxiliary lights, the wires +ve and -ve going directly to the Battery and the White wire going to the +ve in the Thunderbox ( as a split live wire ).
I turn ON the ignition , the auxiliary lights do not come ON ( as expected ), I then START the bike, a few seconds later after the engine is running, the auxiliary lights come on at 50% as DRL ( as expected ) They are bright as daylight @ 50 % - check the video at 31:00 to the end, to see full intensity @ 100%
I turn OFF the bike with the Kill Switch and turn OFF the ignition. The Auxiliary lights are supposed to turn OFF after a few seconds, but they do not ( this is an issue )
Also I need help locating the high beam wire, so I can connect the Denali harness wire to the high beam wire of the bike, so I can control the high beam of the auxiliary light on the same OEM Switch of the bike.
