I haven’t taken the dive yet, still on the fence. There hasn’t been a ton of people that are running them that I could find.Glad I found this discussion, I'm seriously considering changing out to these bars. Thanks to all for the links and photos.
Has anyone actually took the leap and fitted these bars to their NSC?
Well Swanny, I 'think' the Daytona kit will work for the drop and pullback my hands and wrists are crying for. I'm all day comfortable with the high 'clip- ons' my VFR has, and I would welcome a leaning-into-the-wind posture on the NSC.
I didn't have any success with trying to register on the Deutsche Webike site. It would stall out and never respond. But the Japanese site was kind to me and allowed me to register. They won't be back in the office until the 5th, so I have some time to think about it. I'm ready to order as of right now tho.
Will update here....
Nice! Please report back once they get here. I'm excited to hear a review!OK, I just placed the order with Webike Japan for the Daytona clip on set. (Hmmph.. there's no "rubbing hands with glee" emoji, guess this will hafta do) 😄 Should be here in a week or so..
You got it, Swanny!Nice! Please report back once they get here. I'm excited to hear a review!
Wow that’s very quick!The Daytona bar set arrived today! I am blown away by how quickly they arrived: I ordered them Jan 5th, arrived Jan 12th. 7 days from Japan!! I didn't use any fast freight, just the standard EMS to the States, then USPS from LA. So If anyone else wants to order a set, I'd say go for it.
Hope to mount the bars this weekend! View attachment 50800 View attachment 50801
Any update?! I’m too eagerThe Daytona bar set arrived today! I am blown away by how quickly they arrived: I ordered them Jan 5th, arrived Jan 12th. 7 days from Japan!! I didn't use any fast freight, just the standard EMS to the States, then USPS from LA. So If anyone else wants to order a set, I'd say go for it.
hmmmDoes anyone know the brand that makes these bars? I'd love a set for my CB1000R:
Cheers
Crispy
Well then, finished the project last nite and took her out for a shakedown run today. The Daytona clip-on set does what I wanted: more pull-back and more drop angle at the grips than the stock bars. For me, it's "all in the wrist". The stock bars feel straight as a broomstick and twist my wrists and elbows upwards. Uncomfortable for any distance.Any update?! I’m too eager
Sent from my iPhone using Tapatalk
Man these look fantastic.. I’m about to pull the trigger on these. Did you run into any issues with the install?Well then, finished the project last nite and took her out for a shakedown run today. The Daytona clip-on set does what I wanted: more pull-back and more drop angle at the grips than the stock bars. For me, it's "all in the wrist". The stock bars feel straight as a broomstick and twist my wrists and elbows upwards. Uncomfortable for any distance.
IMHO, the Daytona set is very high quality, well-made and uses stainless steel hardware. My only gripe is that it puts the clutch cable in a really sharp bend between the clutch handle and the instrument panel. I will pursue re-routing the cable.
I actually tried mounting the set "upside down" first for better grip angle. Got everything in place, but there was only an eighth inch clearance between the bottom of the switch housing and the tank. Mmmmm a little too close for comfort.
Switched everything back and mounted them as intended, meaning with the "risers" pointing up.
Thanks, Swanny! No issues, really... if you take the actual handlebars out of the risers, you will see a very small pin sticking out of the closed end of the bar. This is a locating pin, it fits into a hole inside of the riser. When you slide the bar back into the riser, rotate the bar so you feel that pin engage and slide into its hole. The handlebars come pre-drilled for the bar end weights and the switch housing locating pins. That's nice, but understand that if you don't like the position of the switch housings and clutch/brake levers when you have everything together, you'll need to drill new holes for your positioning preference. No biggie. Most important is to check switch housing to tank clearance before you torque fasteners the final time.Man these look fantastic.. I’m about to pull the trigger on these. Did you run into any issues with the install?
Thank you for that write up! That’ll absolutely help the install process. If you wouldn’t mind, would you mind taking a couple pictures of the entire bike with the bars, please? I’m curious how it looks with the bar end mirrors too (that’s what I’m also running).Thanks, Swanny! No issues, really... if you take the actual handlebars out of the risers, you will see a very small pin sticking out of the closed end of the bar. This is a locating pin, it fits into a hole inside of the riser. When you slide the bar back into the riser, rotate the bar so you feel that pin engage and slide into its hole. The handlebars come pre-drilled for the bar end weights and the switch housing locating pins. That's nice, but understand that if you don't like the position of the switch housings and clutch/brake levers when you have everything together, you'll need to drill new holes for your positioning preference. No biggie. Most important is to check switch housing to tank clearance before you torque fasteners the final time.
It's high quality Japanese manufactured, and Webike service is exemplary.
I'll snap a couple this afternoon, Swanny!Thank you for that write up! That’ll absolutely help the install process. If you wouldn’t mind, would you mind taking a couple pictures of the entire bike with the bars, please? I’m curious how it looks with the bar end mirrors too (that’s what I’m also running).
