1 - 10 of 10 Posts
Does anyone know the brand that makes these bars? I'd love a set for my CB1000R:
Motorcycle Vehicle Motor vehicle Motorcycle accessories Automotive lighting
Cheers
Crispy
I was guessing Rizoma or De Pretto Moto, but it ain't either of them...
Good looking stuff - good luck!
Same here. I thought Rizoma, LSL or Woodcraft but no joy :(
If you do ever see anything drop me a message as I'm starting to get a little obsessed by them!
not Aella either... spent some time, can't find much yet.
if it is Honda custom (Honda stand at Tokyo motorshow), surely there'd be info on official sites? will keep looking
i like the machining/design, but probably would not use them :p
another Honda exhibit at the motor show... i so like this motor :D
found more.
https://mc-web.jp/topics/17339/
カスタマイズパーツメーカーと協力して理想の形を追求
とはいえ、いくら格好いいものに仕上がったとしても、ただワンオフ部品で全体を飾ってしまっては現実味がない。
そこで、モリワキやデイトナといったアフターパーツメーカーに協力を仰ぎ、「ユーザーさんが実際に装着したくなる」ようなパーツを共同製作。
取り付けられている部品は、デイトナ製試作ハンドル&バーエンドミラー、アクティブ製フロントブレーキレバー、ゲイルスピード製クラッチホルダー、プロト製スウェッジライン(ABS対応ブレーキホース)、モリワキエンジニアリング製クランクケースガード/オイルフィラーキャップ/フェンダーレスキット/バックステップ/マフラー、ハイパープロ製のリヤサスペンション、TSテック製スウェード調ビニールレザー、海外モデル用純正オプション品のメーターバイザー(国内未販売)……と多岐にわたっている。
However, no matter how cool it is, it will be unrealistic if it is decorated with one-off parts.
Therefore, we worked with after-part manufacturers such as Moriwaki and Daytona to jointly produce parts that users would actually want to wear.
The installed parts are Daytona's prototype handlebar & bar end mirror, Active front brake lever, Gale speed clutch holder, Proto's wedge line (ABS brake hose), Moriwaki Engineering's crankcase guard / oil filler cap / Fenderless kit / back step / muffler, Hyper Pro rear suspension, TS Tech suede vinyl leather, Genuine optional meter visor for overseas models (not sold in Japan).
Each part is a reference exhibit of each manufacturer (some of which are already on the market), but according to what I heard, there is a possibility of commercialization depending on the response. It might be a hot story that CB1000R with the same specifications could be produced!
Auto part Motorcycle accessories Bicycle part Vehicle Motorcycle
Nice! Thanks OC. I tried to send Daytona a message via their contact form but it seems like I need to have a japanese contact and address to get one sent through.
Fingers crossed they make it into production
Discussion Starter · #8 · (Edited)
just heard from a Japanese chap on the CB1000R facebook group to the went to the Tokyo show and asked about the bars. Sadly they won't be making it into production :(
안녕하세요. cb1000R 타고 있습니다. daytona15677 제품을 설치하겠습니다. 그러나 손잡이 파이프에 스위치 구멍이 올바르게 뚫려 있습니까? 제품 구매 후 구매자가 직접 구멍을 가공해야 하나요? 아니면 스위치용 구멍이 있는데 위치에 따라 다시 기계로 가공해야 합니까? 회신을 기다리십시오.
Street light Musical instrument accessory Metal Event Composite material
안녕하세요..
in the pictures,, looks like it has the holes.
can you contact the shop and ask about the holes size?
1 - 10 of 10 Posts
