Hi. 2015 CB1000R EU with Akro, decat and O2 eliminator. Had a PCV fitted for a while now using the appropriate map from the website all working ok. Managed to grab an autotune AT200 to go with it this week. Fitted ok, sensor at 12o clock position in the decat link pipe. Existing O2 sensor left in place for now, O2 eliminator already fitted to plug. All connected up and worked first time, lucky me. AFR reading seems fine when bike is running idle and I get the green autotune light fine if I add some revs and I can see it dynamically adjusting the fuel trims to maintain 13.2. I'm using the basic AFR table with everything set to 13.2 apart from the 0 throttle column. No exhaust leaks and I've blocked off the PAIR system by disconnecting the plug from the valve solenoid as per the instructions.
If you have a look at my trim table below after a 10 minute ride its just awful. Starts off fine when the table is zeroed, and then after 5-6 minutes riding the bike becomes very jumpy at around 4000-5000 RPM to the point where it surges forwards without any changes to throttle input, you can also hear the engine chugging like it wants to stall. Above 5000 seems fine no issues but I have to limp back to my driveway after each test ride. Doesn't do it with autotune disabled. engine temperature constant 75 degrees C throughout the ride, only goes up once idling as normal.
My first thought was the sensor, but I've run the self test and it seems ok unless its an intermittent fault be hard to find that if it only happens whilst riding. I thought it might be an exhaust leak but I can't find one and the tables seem to be reducing fuel (if I understand them correctly) meaning the sensor is seeing the AFR as too low/ rich<13.2 so too much fuel in the exhaust rather than too much air. I was thinking of reattaching the PAIR system back up in case unburnt fuel in the exhaust is throwing it off and trying again to see if any different.
First pic shows the fuel map (from dynojet website with -3s added to 0 column to remove popping), second pic is the AFR trim table. I haven't accepted this table, I keep zeroing it and sending it back then trying again but a similar table is built by the autotune again on the next ride so not a one off. I've set the authority to 40% adjustment. 3rd pic shows the AFR target table.
Can anyone see anything I might have missed?
With autotune disabled in the parameter (but still connected so I can see AFR), the AFR display is around 11-12 when revving and around 13 when idling so I can see what its trying to do, lean out the AFR by reducing the fuel to match 13.2.
