1 - 15 of 15 Posts
Doble motorcycles will be checking in on the messageboard every day or so and will do their best to answer any questions you may have.
You might have a technical question or just want to find out how much a part is likely to cost or whether they can provide it.
Whatever the question you can ask Doble Motorcycles right here! :thumbup
A big thank you to Doble for this :thumbup :clap
Please make all individual queries a new thread for ease of use, rather than tag onto someone else's thread :thumbup
Some thing every one wants to know .Do Honda Dealer workshops have the facility via Honda engine management equipment to adjust fuelling for aftermarket exhausts etc as suggested on this forum ?? I personally think not but would be happy to be proved wrong! :thumbup
Banned
Hello Doble, why are the downpipes on the CB so prone to rust, with out riding in the rain, seems to be most if not all CB's suffer with it, would this be valid under warranty, dont get me wrong dont mind cleaning me bike but its probably every time you get home signs of rust are grinning through.
Banned
Antnee said:
How do you suppose stainless-steel pipes are rusting?
point being, none of my other bikes have been as bad, and its only a year old, and to answer a question with a question is not an answer ,and rainman my G strings are washed once a month, whether they need it or not :smoke
I wasn't answering, I was nullifying (?) your question. It is no longer a question, just a statement of universal impossibility and therefore the musings of a mad man (say's me?)
Banned
That must be some good stuff you is a smoking, any chance of an 1/2 ounce? :thumbup
Stainless steel is exactly that..... It is stain less, not impervious to the elements, or stail proof. Rub your downpipes with normal wire wool (Made from iron) and they will definately go rusty, as the carbon will infect the downpipes.
Stainless has many different grades, and the CB's downpipes are about as low as it gets. They add Chromium to make them corrosion resistant, and Nickel to add temperature resistance. The trouble is that they don't add much of either, so the downpipe resistance to corrosion is fairly low.
Hope this helps.
Gargy.
Banned
Hope this helps.
Gargy.
Gargy , that does help, well explained, would of thought being a Honda they would of used a better grade, suppose it comes down to keeping thier cost down, which i think is wrong.
1 - 15 of 15 Posts
