1 - 16 of 16 Posts
Hi there, I have a 2010 cb1000r with 9k on the clock that I have owned for a few months now. The old owner had the bike sat a while so with in the first few weeks the petrol gauge was going centre out showing a fault I’ve ran it with good fuel and that has now stopped doing that completely for the past month. So now ide start the bike okay on a morning and nip 5 minutes down the road and the bike would fail or struggle to start jump with leads and it’s fine ride to work 40 miles starts straight away. Last week I was going to work and at high revs the bike would lose power completely sometimes ignition stays on some times it doesn’t. When I broke down completely the bike would not start again and even eventually the hazard lights wouldn’t work. I jumped with leads was fine again rid to work and started back up for home time but then it did it again on the way home. So I changed the battery thought it was fixed then on the way home from steady revs to a lot or if I wind on fully then just let go it lost all power but ignition was on so I was messing with throttle and a few second later was power again it did this twice. A friend has suggested maybe the stator is bad. Any help would be appreciated. Thank you everyone
The starter motor is struggling to turn the engine over, or the engine is struggling to fire?
When it struggles it’s sounds like it’s struggling to turn over it sounds like its turning over slower and slower the longer I hold in the ignition then sort of wants to turn over a few times then starts or battery dies and over times doesn’t turn over at all battery just dies. I hook the jump leads up then it would fire straight away.
It sort of splutters when it wants to go.
1 - 16 of 16 Posts
